08-29-2012 02:57 AM
And yes, you said something about keep both files and then create a new folder a1.
Then, in the case where 'Keep both' option is executed, see the iamge attached.
08-29-2012 03:36 AM
To Freelance LV
Thankyou for your help, my problem has been solved for now and yes i will post the new query in new post and will look forward for your help and guidance in future also.
08-30-2012 08:07 AM
09-03-2012 01:39 PM
To smercurio fc
Thankyou sir for your suggestion, as you said that there should not be any hard coding paths( by hard coding path ,do you mean the constant path i am giving) in code actually the starting path is constant in my code and after that different folder are created in that path.
and yes also in some earlier posts i had read this that i should not use string functions to build paths but since in my code i am having issue of error 10 which occurs if the folder is already present and the starting path is always constant so to avoid that error i am using string functions(it becomes very complicated when i am trying to use build path function instead of string) but i am trying to solve the problem and would definately replace string functions with the build path functions.
09-04-2012 08:46 AM
@Ritu wrote:
To smercurio fc
Is it constant on another machine? What about if the operating system changes? What about if someone else wants to use it, and they want to save the data somewhere else?
09-04-2012 10:35 AM
To smercurio fc
Yes sir, you are write, we didn't think upon this, Thankyou for the nice sugesstion, i will try to implement what you had said.
