01-02-2013 03:48 PM
i feel that it would be very simple to generate a signal. i tried to create one through DaqAssist and creating a virtual channal AO. when initalizing, i keep getting error/// -88708:
DAQmx Create Channel (AO-Voltage-Basic).vi<append>
<B>Device: </B>Unknown Device
<B>Task Name: </B>_unnamedTask<32>
01-02-2013 06:08 PM - edited 01-02-2013 06:13 PM
<B>Device: </B>Unknown Device<B>Task Name: </B>_unnamedTask<32>
I replied to the wrong post, but I'm interested in this anyway...
01-02-2013 09:33 PM - edited 01-02-2013 09:38 PM
Hello
I would like to know what is the aim of your vi. To generate a signal on an analog output channel? which device are you using?
could you post the vi you are working on? (in LV 2010 or earlier)
the error code you mentioned means that the device is not available. So, may be you are missing something in the code.
it would be simpler to debug the code and then provide any suggestions.
Also, try looking at the two links below:
http://forums.ni.com/t5/LabVIEW/What-is-error-887078/m-p/1331474/highlight/true#M542109
these two links deal with the same error code. So, read them through and see if they can help you out
01-07-2013 04:37 PM
solved it by resetting the compact rio and computer. don't know why it freaked out.
