11-25-2014 06:13 PM
Hi
I am trying to build a packed library from my project. I keep getting an error both with Labview 10 and 2014:
Error 56003 occurred at Invoke Node in AB_Source_VI.lvclass:Copy_SourceItem.vi->AB_Build.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_PackedLibrary.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Adding this item would cause a conflict with another item.
Unfortunately, no information is provided on which "item" is causing the problems.
Any ideas how to identfy the "item"?
11-26-2014 04:10 AM
wsilh, try to create a new project with only this library in it. See what dependencies are pulled with it , maybe a different lvlib/lvlibp is pulled in. Also, be careful where you use the lvlib (uncompiled) and the lvlibp (compiled) because they can clash with each other.
Is this library using another library?
Danielle
11-26-2014 04:54 AM
Also check if the project you use to manage the lvlib/build script has unresolved conflicts. If so, trying to build will most likely fail for conflict reasons.
Norbert
11-26-2014 11:42 AM
Thanks for your replies (also to Norbert)!
I just receated the project and one of the dependencies was showing a conflict that hasn't been there in the old project.
When I created the old project there were several conflicts which I had to fix. Probably I made a mistake with one of these...
(Just for completeness: the project does contain another library with subVIs provided by the hardware manufacturers. Including this library caused most of the original conflicts)
