05-13-2009 03:08 PM
11-12-2015 05:27 AM
Hello everyone,
I made a VI to plot spectrum of the .tdms file of voltage data acquired through NI 9225. Data obtained from tdms read block got successfully shown in the waveform graph. But when i tried to take its FFT or any other spectrum, it is showing error code-20315 (The waveform dt parameter is <=0). I observed using probe wires that value of dt parameter in the data coming from tdms read block is 0. Please suggest me how can i rectify this error or increase the value of dt parameter. VI and .tdms data file are attached here.
11-12-2015 06:02 AM
Your problem could be in your recording. Do you have an example of how you are logging to the TDMS file and possibly an example TDMS file?
11-12-2015 06:45 AM
used data is attached here.........
11-16-2015 04:46 AM
Please suggest something for the above mentioned problem.
11-17-2015 02:00 PM
Hi akanksha91,
As crossrulz suggested this could be an issue related to your recording. How did you log the data?
If what you want is to edit the waveform and set a different time interval (dt) you could use the Build Waveform VI. But you have to be aware that this will change the original waveform.
Build Waveform (Analog Waveform) Function - LabVIEW 2011 Help
http://zone.ni.com/reference/en-XX/help/371361H-01/lvwave/build_waveform/
Carolina
09-12-2016 02:55 PM
Hi Dennis.
My english is not very well, so I try explain my problem.
I have the same problem. I'm using a bending machine, mark Instron. I trying to detect de signal's machine, and detect when the machine is trigger.
I attached my program.
I hope you help me.
09-13-2016 05:13 PM
Hi Makarena.osorio,
It seems that you could use some error handler to skip the error, are you trying to do something like this in one of your subVIs?
09-13-2016 05:13 PM - edited 09-13-2016 05:23 PM
Hi Makarena.osorio,
Also, I added a DAQmx Timing with a rate of 1 between the start and the create channel and I am not seeing the error anymore, try that.
