error 1050 with matlab script
Hi , i'v built an vi which sampling saving and playing audio files , i've also added matlab script for data analysis.
the script tested in matlab and in matlab works great , when im trying to use it in labview i'm getting an error while the matlab sciprt executing . "Error using griddedInterpolant ....."
i think that the error occures whe trying execute the command : "Sigitp = interp1(clptv, clpsig, tv, 'linear'); "
moreover i cant figure how to read the saved filed when the loop is finished.
I cant figure out what is the problem .
here is the vi :
i've also included the vi
(4,266 Views)
Accepted by topic author Cobmetal
found out how to get this work out , the problem was with input to the matlab script .
(4,205 Views)
For anyone thinking of basing their code on this example: This is not a recommended solution to the problem.  Execution order is artificially enforced by using a sequence structure when it should be done using dataflow basics.  See this link for some very good tutorials.  By understanding dataflow basics - the heart of LabVIEW - you should almost never need a sequence structure.
Bill
CLD
(Mid-Level minion.)
(4,193 Views)
Im novice to labview , and im learning a lot from NI community , thank you for your suggestion , i will go over it , and try to learn the proper way to implement such tasks in the future.
Thank You.
(4,186 Views)
Thank You.
That's excellent!  I believe that if you truly understand dataflow, you will see why your solution isn't the best one.  ASK QUESTIONS IF YOU DON'T UNDERSTAND SOMETHING.  I put that in bold caps because we are here to help you understand and get better.  🙂
Example:
"According to what I learned about dataflow, I think this part of my solution mentioned above can look like this.  (Upload picture.)  Does that seem right to you?"
Bill
CLD
(Mid-Level minion.)
(4,181 Views)
Smiley Wink
(4,175 Views)
