03-12-2015 10:28 AM
03-12-2015 10:56 AM
03-13-2015 09:18 AM - edited 03-13-2015 09:22 AM
i removed them from ni daqmax. and configured all in trd ni daq MAX. then for moment it shows error :
10001 occured at DIO port config, an error was detected in the input string: the rrangement or odering of the chracters in the string is not consistant with expected ordering.
but if i say to continue every second again and again neglecting fault analogue display on screen show reading changes every second with fault to continue
when i configured modules
chaises id =1, chaises address= 0
for scxi 1303
cabled device to 6052
operaing mode : multiplex
attached access: scxi 1102c
for 1325
cabled device : nil
attached access: scxi 1124
for 1326
cabled device : nil
attached access: scxi 1162hv
for 1324
cabled device : nil
attached access: scxi 1160
in Ni daqmax it was not showing readings
do i need to configure indivisual channels??? input and outputs????? and how to know
03-17-2015 09:56 AM
