08-30-2005 07:38 AM
08-30-2005 08:02 AM
How about the attached, which someone attached here as a workaround for RT, where the reference would be no good? It uses the Type Descriptor to get the strings. You can probably dig around some more to get the values.
Another possible option would be the OpenG data tools, which may also deal with this.
08-30-2005 08:21 AM
08-30-2005 08:40 AM
I'm not sure I understand.
Some further digging shows that an enum can not have discontinuous values and that it can not have duplicate values. If this is so, you can READ its Strings[] property and use Search 1D Array to know which value to assign it. Isn't that right?
08-30-2005 09:32 AM
08-30-2005 09:47 AM
Just as much as a male would have Lucy (my previous, and probably future, avatar as she didn't get enough time) as his avatar. And if you're thinking of masculine characters, don't Sam & Max fit better?
@shoneill wrote:
PS I reckon you've given away your gender. Would a female ever have mightymouse as their avatar?
08-30-2005 10:06 AM
08-31-2005 08:30 AM
08-31-2005 09:42 AM
08-31-2005 11:48 AM
