04-22-2015 11:05 AM
I cannot explain a strange behaviour, I hope someone can give me a hint.
First of all, do not ask why I need this way to go, I just would like to understand why it happens.
We have a FGV which has 3 actions: Init, Write data and Close. This operates on TDMS files. The init action creates a TDMS file reference which is stored in a shift register to be ready used by the Write and finally the Close cases.
All is OK, if I use this FGV simply in a main VI directly from the block diagram. So I can init, write data, and finally close the TDMS file.
However, for a certain reason, a new requirement appeared: to be able to "Init" and "Close" the TDMS file using the FGV, but from inside a dynamically called VI (a pop up window which is not allowed to stop the execution of the caller).
So in the main VI, I dynamically call another VI using the Async call (flag x80, "call and forget" methode), and this dynamically called VI fires the TDMS FGV.
When I probe the TDMS file reference, I can see it gets its value properly after the "Init" case was fired. After this "init" happened (from the dynamically called VI), a location in the MAIN VI starts to call this FGV with the "Write" enum action. I can see via the probes, that the Write case gets the very same TDMS file ref number what was stored in the shift register after the "Init" case.
But even though, the VERY first TDMS Write function throws a "TDMS file reference invalid" error msg! How can it be possible, if the file reference is OK and the same as the one created by the "Open TDMS file" function in the "init" case?
I repeat, if I execute the "init" action also directly from the main VI, not from a dynamically called third VI, all is OK, it works.
I hope my explanation is not too bad 🙂
Thanks for any hints, and if no idea, I will try to recreate/reproduce this behaviour in a test project which is small, and I will post it...
Solved! Go to Solution.
04-22-2015 11:37 AM
I just created a small example. Here it comes!
04-22-2015 01:37 PM
04-22-2015 01:47 PM
I have still lots of things to learn 🙂
Could you clarify further?
"The problem is that when the dynamically called vi stops any references it opened go invalid."
Hmm, this dynamically called VI does not open any reference. It executes the FGV which creates and stores the TDMS file ref inside its shift register. You mean, even the FGV which is called from this dynamic VI, "loses" its reference, it goes to invalid? How can this problem be avoided? I mean, to avoid that if we call an FGV from a dynamic VI, it loses its opened references? I always thought an FGV is a safe storage even between VIs? Not in this case...?
Thanks! I learn something new now 🙂
04-22-2015 01:51 PM
04-22-2015 01:54 PM
