dressler
HERE The image of the block diagram of my vi code
Message 11 of 13
(731 Views)
None of that appears correct. Is your string constant of 165 set for hex display? Why append what looks like a carriage return or line feed? Where is the necessary checksum? Connecting the number of bytes Wooten to the number of bytes to read is just wrong.
Place a U8 array on the block diagram and set it for hex display. Enter the necessary values into the artsy and convert it to a string with the Byte Array to String function.
Message 12 of 13
(724 Views)
To configure the serial port of the generator cesar 1312, two protocol, AE BUS PROTOCOL and dressler. I have chosen the dressler protocol, but I get the message "no command".
Message 13 of 13
(694 Views)
