06-25-2013 08:44 AM
LV 2012 Pro V1.0.1f3. No special font settings. I went into my options to make sure.
06-25-2013 09:27 AM
Are both LV and Windows 64-bits?
@Paul: The version number you refer to is SP1, isn't it?
Norbert
06-25-2013 09:56 AM
no only win7 is 64 bit, LV is 32 bit (Full development System Version 12.0.1f3)
Regards Florian
06-25-2013 10:07 AM
Ok, just for clarification: By dragging a path, you refer to dragging the path from a Windows File Explorer window to the LV Block Diagram window just like this:
I tested my LV 2012 (no SP) 32-bit with Win 7 64-bit and it doesnt drop anything. So i would say that i see the behavior you describe. Correct?
Norbert
06-25-2013 10:29 AM
Correct,
though it bugs me more that the snippets don't drop as intended.
Regards Florian
06-25-2013 10:38 AM
Yes, SP1. Windows and LV are both 32-bit
06-25-2013 11:16 AM
From Windows explorer I used to be able to drag a file or folder into a path constant on a block diagram and that file or folder path would drop into the constant. Same thing with snippets. Now I can't. I get a "not" - looking cursor and nothing happens.
As a work-around I can right-click and browse to the file or path (a real pain) but snippets still don't work.
Windows drag-and-drop between windows works fine.
06-26-2013 02:16 AM
@PaulG. wrote:
From Windows explorer I used to be able to drag a file or folder into a path constant on a block diagram and that file or folder path would drop into the constant. [...]
OK, using LV 2012 32 bit without SP running on Win7 64bit, i cannot reproduce this. I will try to get my hands on a machine with SP1 on hopefully both Win7 (32/64bit) and try it there. It really sounds like a bug, but without reproducing it, i will not further comment this 😉
Norbert
06-26-2013 02:35 AM
I it working for me.
Windows 7 Enterprice SP1 64 bit
LabVIEW Dev. Suite 2012 SP1 1.01f3 32 bit.
I can drag and drop a file from windows explorer to a path constant on the block diagram and get the path to that file.
I can also drag and drop a snippet to the block diagram to get the code.
06-26-2013 02:38 AM
PaulG. and I both have LV 2011 SP1 installed besides LV 2012.
Could this contribute to the issue?
Regards Florian
