06-24-2013 08:40 AM
This used to work, but somewhere along the way I lost the ability to drag and drop file paths and LV snippets onto a LV block diagram. Has anyone else seen this? I don't think it's a windows issue. And it works in LV2011.
Solved! Go to Solution.
06-24-2013 08:43 AM
Paul,
never seen this, sorry.
Is there a difference if you run LV 2012 "as admin"?
Norbert
06-24-2013 08:57 AM
Yes, I run as admin. I need to read/write Excel files.
06-24-2013 09:28 AM
Paul,
ok, standard support question on Windows: Does this also occur after reboot?
And my question refers to the right click >> Run as administrator option. It was not the question if your login has administrative rights.... sorry for the confusion.
Norbert
06-24-2013 09:35 AM - edited 06-24-2013 09:35 AM
LV snippets import fine for me still in LV2012, and I can still drag files from Explorer to a file path constant.
06-24-2013 10:30 AM
Yes, it occurs after reboot and when I right-click>run as administrator. I was hoping there was a simple setting that someone here might have recognized right away. I've had some issues running our bastardized "coporate" version of Win 7 "enterprise" with LV but it's behaving the same way on another machine running a generic version of Win 7 pro.
06-24-2013 10:50 AM - edited 06-24-2013 10:50 AM
If you are using an AVEO Theme try changing to Windows Classic. If that allows you to recover Drag-n-Drop I'd love to see a "Jing" of the behavior
06-24-2013 01:51 PM
Was not running an Aveo theme but a custome theme. Changed to Windows Classic and rebooted but still seeing the behavior.
06-25-2013 02:09 AM
What kind of LV license do you have? Is it a professional package?
Do you use special settings for fonts?
Norbert
06-25-2013 08:22 AM
I experienced the same problem today. First time I tried it with LV2012 SP1. Windows version is: 7 Home Premium SP1 64 bit.
At first I thought I had a problem with IE - but it wouldn't work from desktop either.
I Have tried it in LV2011 SP1 - works fine.
Regards Florian
