Hi Guruthilak,
you say "
Now i understand that you would like to rearrange the "target control" then select the "move only " options in the "drag mode" (right click on the control and select the "drag and drop" option.
If you want to duplicate the value in the control use the option 'copy only' ".
it's not working when i select the option in darg mode to move only it's still create a duplicate values in the target?...
