09-08-2010 08:38 PM
Hi all,
I want to downconvert IQ signal that is not centered around zero. I don't wan't to use the MT downconvert passband VI with its complex input mode selected...One option could be that i upconvert the signal to some higher frequency say 'freq1' and then downconvert freq1 to zero but for this i'll have to resample the signal first at least 2*freq1 that i don't want to do, coz it requires more processing. Is there any way to directly perform downconversion without doing upconversion and resampling?
thanks
09-09-2010 09:03 AM - edited 09-09-2010 09:05 AM
If you know the center frequency if the IQ data then just multiply by cosine(2*pi*fc*t) for the I part and sine(2*pi*fc*t) for the Q part. Lowpass filter both signals to remove the higher frequency component. What is the sampling frequency and the center frequency of the data?
09-09-2010 12:03 PM
I have acquired a band of 4MHz IQ data that is centered around zero with an IQ rate of 5MHz. So, the spectrum spans from -2.5MHz to +2.5MHz. This 4MHz band has one signal centered around +1MHz, one centered around 0, and another one centered around -1MHz. All three signals have a bandwidth of 200kHz. I want to down convert the +1MHz and -1MHz signals to zero.
09-10-2010 10:07 AM - edited 09-10-2010 10:09 AM
I think, and I haven't had a chance to verify, instead of mixing down by multiplying with a cos(2*pi*1MHZ*t) or sin(2*pi*1MHZ*t), you need to multiply by [cos(2*pi*1MHZ*t) + i*sin(2*pi*1MHZ*t)] for the 1 MHz signal and by [cos(2*pi*1MHZ*t) - i*sin(2*pi*1MHZ*t)] for the -1 MHz. The complex sinusoids should give you only one impulse signal, if you are looking in the frequency domain, to convolve against.
09-15-2010 03:29 AM
Thanks. It works!
