12-05-2008 03:16 PM
Best question to ask is how do I build a parameter from the using the the call function library node in LabVIEW 8.6: function prototype is the following as defined in the H file:
C1218 API int __stdcall OpenSerialPort(char *comPort, errorStruct & err);
in the H file errorStruct is defined as follows
typedef struct
int code;
char * msg;
int msgMaxLenth;
} errorStruct;
this DLL does wrong with test stand, but not using Test Stand, only LabVIEW.
Solved! Go to Solution.
12-05-2008 11:36 PM
Duplicate post. Continue here.
Try to stick to a single thread. Please wait patiently for sometime. Somebody will surely help you to solve your problem.
12-08-2008 11:43 AM
