10-25-2012 01:50 AM
i have problems when i try to use a dll : function doesn't appears in "Function name" menu, BUT when I manually type the expected function name(ReadMemory), the Call Library Function auto updates parameters, and so the Function prototype.
So it's as if Labview see the function, but can not use it (there is always the error "The function name specified for this node cannot be found in the library.", so the wi can not be executed).
Do you have any idea how to use this dll ?
Best Regards,
10-25-2012 08:15 AM
Hi found the problem : the functions can not be openend with a call library function, but it works with ActiveX.
So if someone give you a DLL without any documentation, try to use ActiveX !
Best Regards,
10-25-2012 08:44 AM - edited 10-25-2012 08:46 AM
Best Regards,
Code, without documentation, is usually called "A BUG" by software developers. and we won't use it at all!
Fair warning.
