07-09-2006 02:22 AM
07-10-2006 02:52 AM
07-10-2006 03:03 AM
07-10-2006 03:14 AM
You might be using the NI CAN but the application exe you are using has probably not been built with the NI CAN API.
If you have the source code, you will have to rebuild the software using the NI CAN API. Probably not as straight forward as it sounds because the function calls will be different.
Regards
Ray Farmer
07-10-2006 03:20 AM
Hello!
Ok, you are using a NI-CAN interface and should therefore use the NI-CAN driver that you already have installed. Have you used Kvaser functions before? Because I have installed the Kvaser NI-CAN driver and indeed the canlib32.dll is installed with their driver and when you look at the DLL's properties you will find information that it delivered by them.
