01-21-2014 08:56 AM
Attached is a vi showing two methods for displaying plots point by point, the second method is usually but not suitable for my application because it needs one shift register per plot.
I'd use the simplest method (the first) to display a graph with only one shift register but the XY graph does not accept more than 2 plots!
01-22-2014 10:02 AM
Hi Cinou
You may get a better response if you submit your VI in an earlier version of LabView as only a limited number of forum members have LV 2013. Goto 'File > Save for Previous Version' and select LV 2012 or earlier.
01-22-2014 10:14 AM
This may just point out my relative newness to LabVIEW, but what is the problem with having a separate shift register for each plot on the graph?
Cameron
01-22-2014 10:15 AM
