12-05-2008 05:23 PM
How can one plot the waveform ( for example - fequency response ) over one complete period?.
I could only display it over 0 to pi.
Can i do it over 0 to 2*pi or perhaps -pi to + pi?
( i used the waveform chart and connected to it, the output of frequency response of the frequency analysis vi )
Many Thanks,
Kishore.
12-05-2008 06:05 PM
Hello Kishore,
I normally use Waveform Graphs, not Charts. Essentailly, graphs generate a new plot each time they receive the data, whereas a chart appends the data. As a default, they generally display all of the data passed to them, and adjust automatically to fit the data. However, all of the grpahs parameters are accessible through property nodes.
12-05-2008 07:22 PM
Hello Paul,
Thanks for the reply. I now checked properties menu of the Waveform Graphs, where i was able to change the display scale - Minimum and maximum.
for example - If i give scale over one period say -pi to +pi or 0 to 2*pi - i get the graph scales visible, but the frequency response replica is not available.
But i have included complex congugate poles and zeros in my filter design. Is it a problem with the filter design ? .I am new to labview and hence the question.
Also i could not get any options under properties of filter analysis vi.
Thanks again.
12-06-2008 03:12 AM
Am new to Labview as well.
I am facing the same problem as you have stated. First of all, am able to plot Frequency response only as a normalised frequency. And not in radian. i could give values from -0.5 to 0.5 for an entire period. I wanted it in terms of radian (-pi to pi) - is this possible?
Also, when i gave -0.5 to 0.5, the graph was drawn only for 0 to 0.5 - i could not see a response on the negative half plane (even though the filter was designed for the negative values also)
How did you solve the issue?
Arch
12-06-2008 06:27 AM
12-06-2008 06:20 PM
12-07-2008 04:51 AM
Maybe we can help you if you post a more thorough description of your problem.
12-07-2008 02:27 PM
Hi All,
I have designed a simple digital resonator filter having 4 poles and 4 zeroes. The peaks/poles are at pi/3, 2pi/3, -pi/3 and -2pi/3.
I gave the output of this filter into a filter analysis block. From this block's output, i am trying to plot the magnitude, phase and the poles and zeroes plotted in zplane.
The scale of the graph drawn has been changed to show -pi to pi (X scale)
The expected output is to show peaks at the 4 peaks mentioned above.
But what i see in the output is only 2 peaks (at pi/3 and 2pi/3 ). Am not able to get the peaks at the negative frequency. (-pi/3 and -2pi/3) - both magnitude and phase response.
Also, the z plane graph shows only the upper half of the unit circle. the lower half of the unit circle itself does not get drawn. (Even though i have changed the scales to show negative values)
Am not sure how to get this done.
I hope this is a better explanation.
And am really hoping someone could point out what the obvious issue is. (Am sure its not the filter design problem 🙂 ) Any thoughts?
Is there any property in the graph we should be changing other than the 'scale'?
Arch
12-07-2008 08:14 PM
12-08-2008 01:25 PM
