05-21-2012 10:05 AM
Hi all,
How do i call/display VI Hierarchy Window programmatically>?
thank's.
Solved! Go to Solution.
05-21-2012 10:40 AM
Use the Application Method "Get Hierachy Image Scaled" and display it using Draw Flattend Image with a picture control.
Christian
05-21-2012 10:47 AM
I know it's not a good solution but here's one :
Epictetus
05-22-2012 12:32 AM
Hi Christian,
can you please send an example?
regard's
eyal.
05-22-2012 12:56 AM
Christian
Indeed, can you show how to use this method properly, I keep getting either nothing or a "not enough memory to complete this operation"...
Epictetus
05-22-2012 01:10 AM
Yes I have tried it works for me without any problem. Am able to save the image to a file and read it and display that to a picture indicator.
05-22-2012 01:25 AM
not working for me...getting nothing.see the attachment.did i do somthing worng?
05-22-2012 01:30 AM - edited 05-22-2012 01:33 AM
Yes in 2009 it is not working but the same works fine in LV 2011. Check the attachements
05-22-2012 01:32 AM
i have labview 2011 still not working.....? can u send the image of what u did?
05-22-2012 01:32 AM
I can't get the same code to work in LV 2010.
Epictetus
