09-12-2006 12:37 PM
09-12-2006 01:11 PM - edited 09-12-2006 01:11 PM
Message Edité par Conseils le 09-12-2006 08:12 PM
09-12-2006 01:46 PM
This could be the cables/ckt response to a step stimulus.
A low pass filter, or using a buffer to make sure you do not have reflections on your transmision line may help that situation.
Ben
09-12-2006 02:44 PM
09-14-2006 03:03 PM
Hi all:
Thanks a lot for all of your responses.
My setup has an eddy-current displacement sensor and NI 4472 DSA. I'm measuring the vertical displacement of a rotating shaft (at 120 RPM); a very basic setup.
I use PFI0 external trigger to collect data from optical encoder (one pulse/rev) at a certain angular location of the rotating shaft. The noise comes only when I use external trigger. I used a function generator instead of the encoder, but I still have the noise. I'm using screened wires and I kept them away from all other noises. I have another setup that collect data continuously without trigger; it does not have any noise at all.
Also, the noise appear only at high sampling rates. If I go over 20,000 samples/sec, it shows visible noise modulated over the regular waveform (see figure). As I reach 40,000 samples/sec, you will see a large carrier frequency all over the signal.
Again, nothing happens when I do not use regular Labview code with continuous collection. It takes place when I use trigger and when the sampling rate is above 20k / sec.
I have attached my VI and a sub VI i use.
Thanks in advance for your help.
Vipul.
09-14-2006 03:16 PM
