10-08-2008 01:55 PM
Every time I create a new controller/indicator from the block diagram windows, it keeps placing the newly created controller/indicator from block diagram windows as "view as icon". How do I disable this view so that it always default to false? I don't want view as icon.
10-08-2008 02:04 PM
10-08-2008 05:06 PM
11-09-2009 09:40 AM
11-09-2009 09:43 AM
11-09-2009 09:45 AM
11-09-2009 10:18 AM
On the same lines here...
Is there a way to make the express vi's (mainly the Time Dealy vi) default to "view as icon" on the block diagram?
04-09-2015 03:30 PM
I never understood why this is enabled as a default. Is there any benefit to having an object that is 3x as large as a front panel terminal symbol? Block diagrams get very crowded for space once your code becomes rather complicated.
I switch mine off as well.
04-09-2015 03:55 PM
Apparently new users prefer the big and bulky.
As for the express VI's that is a good suggestion and I've never found a way for an express VI to default as a small Icon View (and turn off the caption). If this is hidden INI key I want it.
But honestly I use express VIs so seldom that it doesn't bother me too much.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-09-2015 04:16 PM
Thanks for pointing that out to me. I can't believe NI would consider nuking the small terminal symbol in future releases.
Everytime I drop one of those dopey looking icon terminals on my diagram and revisit the code later, for a split second my mind reacts "where did that silly looking sub-routine come from? who made that?" and then I recall it is just a terminal with a pitiutary malfunction.
