04-27-2015 01:38 PM
I am trying to generate a square pulse with an NI 9263. I am testing latching solenoids, and need a fairly accurate amplitude and pulsewidth. I tried with the VI in the picture. My goal is 32ms +/-1ms. This VI produced a pulse anywhere from 25.5ms to 36ms. I passed the same waveform into a DAQ assistant and it was 32.2ms every time, but the size of the VI tripled. How can I achieve the same results using the LV primatives?
Solved! Go to Solution.
04-27-2015 05:13 PM
04-27-2015 06:15 PM
Thank you Mike, I will try that in the morning!
04-28-2015 09:33 AM
That is awesome Mike! Thanks for the tip. The VI that it converted to is about 2/3 the size of the assistant. And it is a great tutorial. The LV code actually looks better than some of the examples included with LabVIEW.
