12-13-2006 03:11 PM
12-14-2006 05:31 PM
Hi Diane,
As outlined in the Error -200563 From a DAQmx Digital Input Task knowledge base, to use the port format, DAQmx can only read a complete port. In the case of the USB-6259 the port is 32 lines or bits. If you need to get the data into a U8 format, you can use the waveform option for the DAQmx read VI and convert the data to U8 using a "digital to binary" function.
Hopefully this helps,
Jennifer O.
12-15-2006 11:35 AM
Yeah, you'll have to read the full 32-bit port, perform an AND with hex 0xFF00 to mask off input bits 8-15, logical shift-right by 8 bits to move them down to bits 0-7, then convert to U8.
On the output side I *think* (but am not sure) that the driver performs automatic masking based on the bits you originally specified in the virtual channel when setting up the output task. If I'm right, then it won't matter what is contained in the upper 24 bits of the u32 values you write to the task, only the lower 8 bit values would actually be written.
Side note: In the old traditional NI-DAQ Port Write vi, one would wire in both a u32 bit value AND a u32 bit mask. Internally, only the value bits corresponding to 1's in the bit mask would be written. All other bits would be left in their prior state. This type of specification with both bit value and bit mask isn't needed in all apps, but it is quite handy in some. The mask bit is like an Enable, controlling whether or not the new write bit gets through.
Under DAQmx, I don't recall a way to perform this same function. I think you'd need to do it in your own code with bit-wise logic functions. For apps that need it, this is one of the areas where the DAQmx interface can be more cumbersome than the old traditional NI-DAQ interface. Here's what I *think* you'd need to do to accomplish masking of some of your output bits.
1. Perform DAQmx Read on your output task. This should return the bit value of all your output bits and 0's for all other bits. (I'm not sure if this can be done on buffered output tasks though.)
2. Use bitwise operators to produce the bit pattern to write. Maybe there's a more compact way to do this, but here's what I came up with:
Let C = Current bit pattern from read, N = New bit pattern, M = Mask bit pattern of mask, W = bit pattern to Write
Desire: Each 1 bit in Mask selects corresponding bit from N, Each 0 bit in Mask selects corresponding bit from C.
Expression: W = (NOT(M) AND C) OR (M AND N)
3. Write bit pattern W using DAQmx Write.
-Kevin P..
12-18-2006 12:15 PM
12-18-2006 01:32 PM - edited 12-18-2006 01:32 PM
Some bits of clarification:
1. You definitely CAN have buffered DI and buffered DO tasks operating simultaneously, provided they access different bits of port 0 on a 6259. I've had success with this in an app with 8 DO bits and 24 DI bits that were buffered by a shared sampling clock, outputs on leading edge & inputs on trailing edge. This ran at 10 kHz in hardware. I read, processed, and reacted to the incoming DI patterns at 100 Hz.
2. As I said before, in a buffered DO task, I suspect you aren't allowed to perform a DAQmx Read to peek at the instantaneous state of the output bits. In an unbuffered "on-demand" type of task, you definitely can.
3. Early on, I discovered issues with the "TotalSamplesGenerated" property of the DO task. It reported the # of samples that had been moved from system RAM to the data acq board, NOT the # of samples that had actually been clocked out to the output pins. Since my DI task shared the same clock, my workaround was to query the "TotalSamplesAcquired" property from the DI task. Hopefully, you can do something similar to keep DO and DI in sync.
My app regenerated a fixed pattern, so by knowing the # of sample clock cycles that had passed, I could figure out the DO pattern for that cycle and thereby also figure out the expected DI pattern. So, lacking the ability to directly read the output bits, I maintained a means to "look up" the DO pattern for any given cycle(s) I needed.
-Kevin P.
EDIT: simple proofreading
Message Edited by Kevin Price on 12-18-2006 02:35 PM
12-18-2006 01:53 PM
Hi Kevin,
Thanks for the response!
I'm reading / writing a fixed number of samples, so I actually don't need a real-time look at the instantaneous state of the input lines. The VI runs, uses Digital Read to collect the specified number of samples and output an array containing the values, and then I process the array. So if the port will handle the simultaneous DI / DO ok (provided, as you said, that I specify different bits on the port for each operation), then everything should be golden. If the DI operation and the DO operation are using the same clock, they shouldn't get out of sync, should they? By no means am I reading / writing large amounts of data -- the largest number of samples I'll ever need to process is something like 100. I need to run the operation at 100kHz, but that should be well within the board's capability. I just need to make sure that I read one port value for each one I write, otherwise I'll miss data and my software will become confused and grumpy.
So given that I don't need real-time samples of the state of the digital lines, does it sound like the simultaneous operation should work if I just use the U32 version of the DAQ VIs? My exisiting array processing routine should work regardless of whether I'm looking at U8 or U32 (or U16, for that matter) so that's not an issue.
Thanks a lot for all of your help!
Diane
12-18-2006 02:54 PM
