04-03-2014 03:32 AM
Thanks for the reply,
Can you help me with, how can i get the signal to my output channel from the snippet you attached.
So getting the output on my digital channels.
kind regards,
04-03-2014 03:37 AM
04-03-2014 03:45 AM
Thanks a lot 🙂
04-03-2014 10:47 AM
Hi GerdW,
I am now using the output on my Digital channel. But I have a one small error.
When I press the stop button the output on the channel where I stopped it stays high untill i disconnet the usb cable.
I would like to have it in such a way, that when i hit the stop button the output is low on all the channels.
Can you help maybe?
Thanks.
Kind Regards.
04-03-2014 01:00 PM
You just need to do one more write after the loop where you send it an array of all Falses before you stop the task.
04-04-2014 01:51 AM
can you maybe give me an example, How to do it. I tried something but i guess i am did it wrong.
Thanks.
Kind Regards,
04-04-2014 01:52 AM
04-04-2014 02:05 AM - edited 04-04-2014 02:06 AM
Here is the VI.
In this case on the Front panel i see the LED shifting but on the digital output of the Data acquistion the 1st channel stays high all the time.
But I want it the VI to stop output of all the channels when i press stop.
Thanks.
Kind regards,
04-04-2014 02:07 AM - edited 04-04-2014 02:09 AM
As said before: usually you should attach your VI, so we can give suggestions for improvements…
Edit: That's a picture, but no VI…
Solution: THINK DATAFLOW!
Did you debug your VI with highlighting enabled? Then you would notice why it behaves like it does and where the problem comes from…
04-04-2014 02:11 AM
Here is the VI.
I thought we could use in to drag in the block diagram. Sorry for that.
