different sampling rate for daq inputs
i am using daq card 9025.
i wish to take two inputs at different channels but with different sampling frequency..
cani do this using daq assistant ?
or i wud have to use traditional daqmx functions?
could anyone shelp me with one example?
(3,021 Views)
I would sample them both at the higher frequency, then decimate the data for the slower channel.
steve
Help the forum when you get help. Click the "Solution?" icon on the reply that answers your
question. Give "Kudos" to replies that help.
(3,013 Views)
A 9025 is a cRIO controller.  I don't think that is what you have.  Perhaps you meant a 9205, which is a 32 channel AI module.
All imputs from a single module will have to be read at the same rate.  If you want to run at different frequencies, you will need to have another module.  What I tend to do in similar situations is just read at the fastest rate needed and then just perform an average on the channels that should be at a slower rate.
GCentral
(3,011 Views)
and what averaging function would that be?
(3,007 Views)
I typically used Mean.vi (does not get any simpler than that).
GCentral
(3,002 Views)
