different labview tab colors
Image of Tim's code.
Ben
Message 11 of 16
(2,358 Views)
I would like to change tab name color. I've tried a lot of things but I can't do it.
Which parameters should I use?
thanks
Message 12 of 16
(2,256 Views)
Its a similar set of property nodes, you can also show and hide the tabs... see the attached vi.
Edit: Sorry - I just reread your post. You want to change the tab name colour, not the tab name. My attachment won't do that, but I'll leave it here anyway in case it helps someone else.
Cheers
Ian
Message Edited by _Ian_ on 05-11-2010 07:35 AM
Message 13 of 16
(2,240 Views)
I thougth that i was similar but it doesn't seems so easy.
I'd like to displays the name of each tab in color!
Message 14 of 16
(2,222 Views)
All is not lost (yet) !
In this thread I posted how to add custom graphics to the tab. With the right graphics you get close.
Ben
Message 15 of 16
(2,216 Views)
The above images shows a quick import of images to the tabs. More exotic images would look better and I don't know how to change the images at run time.
Ben
Message 16 of 16
(2,203 Views)
