08-01-2009 05:11 AM
Hi All,
I m designing an occupancy control in LAbview based on the delay in sensing by the two infrared sensors installed!
Is there any tool in Labview which can sense the delay in the input recieved by the two detectors and accordingly act!!
Also, I want to initialize a variable "Sum" in a case structure which continuously decrements or increments by 1 every time it checks if the input is true or not!! But initial value is "ZEro" whenever i first switch on the program. IT is something like a counter.
Please Help!!!!
08-01-2009 08:40 AM
Please! try! to! refrain! from! so! many! exclamation! points!
What kind of hardware are you using to detect the sensors. If you have an NI DAQ board, many of these have a counter and that would be the best way.
Your software counter can be easily implmented with a shift register.
08-01-2009 10:24 AM
I am designing an occupancy control of a room. It will be maintaining the total count of people in a room i.e. incrementing the count by 1 whenever someone enters and decrement the same by 1 if someone exits
The occupancy logic is based on case structure. Anyways the prob can be solved?
08-01-2009 11:11 AM
The problem can be solved but you need to answer the question I asked.
Again - What hardware are you using to detect the sensors?
The logic of your program has nothing to do with the basic question above. If you have nothing to detect a sensor, you can't begin. And, as I said, the increment/decrement is done with a simple shift register. For learning the basics of LabVIEW, you should look at the tutorials. It's also a question that has been asked/answered a large number of times. Plenty of examples to look at if you do a search.
08-01-2009 11:41 AM
Dennis Knutson wrote:Please! try! to! refrain! from! so! many! exclamation! points!
Reminds me of the Seinfeld episode. http://www.youtube.com/watch?v=3rd7j-aSqFU
08-04-2009 05:20 AM
So this doesnt solve your problem?
Even If your answer is going to be "no" You can continue in the same thread.... "!"
