02-19-2014 01:09 AM
Hi all,
I have read through a number of posts and knowledge base articles and I'm not sure if what I am trying to do is possible.
In short, I have a subVI that is always running in a while loop of the main VI. When i close the front pannel of the subVI I would like to change the status of a boolean switch in the main VI. Note that the subVI is still running even after I close it's front pannel.
I know it's not recommended, but I am already using several global valiables to pass several statuses ('control system running', 'front pannel visible', 'test running' etc) between the main VI and subVI.
When I change the boolean switch that I mentioned before to a 'true', this changes the global variable 'control system running' to 'true' so that the subVI knows to execute a certain state. When I manually close the subVI (using a stop button), the status of the global variable 'constrol system running' gets changed to 'false.' I would like for the boolean switch to be changed back to 'false' after the subVI front panel closes.
Any help would be appreciated. Thanks in advance.
02-19-2014 03:09 AM
Generate a user event in the sub-vi which the main vi listens to.
/Y
02-19-2014 04:29 AM
How would I get the main VI to listen to the subVI? Get the subVI to write the user generated event to a global variable, and have the main VI continiously poll the global variable? I was hoping there would be a more efficient way than polling.
02-19-2014 04:46 AM
You create a user event in the main vi and register to it. You send the event-ref as input to the sub-vi so it can generate this event. No polling.
/Y
02-19-2014 04:48 AM
You can also send the boolean button ref to the sub-vi and generate a value change-event on the button, which you'll need to listen to.
/Y
02-19-2014 07:58 AM
I would recommend a user event. You create the user event and register for it in the main VI. The event structure in the main VI can then be watching for the event. You can also have whatever data you want in the user event, so it isn't just limited to the boolean.
So then you just pass the User Event reference into the subVI. The subVI can then generate the event when you close the panel.
02-19-2014 07:31 PM
Yamaeda: What is the point in sending a reference to the boolean button to the subVI? As I understand you cannot write to a reference, and I want the information to flow from the subVI to the main VI, not vice versa.
Crossrulz: For the user event in the main VI, what do I use as the 'event source'? I can't access the subVI's 'STOP' button from the main VI.
02-19-2014 07:53 PM
Once you understand how to fix this problem, you will also understand how to avoid using the globals to pass data out of your subVI, too. It's not only not recommended to use globals for this purpose, it's dangerous. You'll never know if you are reading stale data.
02-20-2014 02:54 AM
When you define your event you also decide which data it should work with, it could e.g. be a typedef'd enum of Commands. Thus you can send a bunch of different commands with the same event. If you want it very general you make it a cluster with 2 elements, a command enum and a variant.
The point being that the event doesn't affect your main boolean, it fires an event you catch and react to, by e.g. switching the boolean.
/Y
02-20-2014 06:44 AM
I recommend going into the LabVIEW Example Finder (Help->Find Examples) and do a search for User Event. That should get you started with using user events.
