10-09-2014 10:47 PM
helo everyone, i'm rai from indonesia Would you like to help me ?
I have a design project pulse oximeter lbased abview Arduino. I have a problem how to process the signals obtained from the sensor.?
how do I find the maximum and minimum peak values as shows up in the picture below?
I've been able to acquire data from the sensors using labview interface Arduino as shown below
I've managed to acquisitions data from the sensor spo2 use interface labview arduino as shown below .
thank you very much
10-10-2014 05:29 PM
Hello Rai,
I'd suggesting looking at this example for how to determine the maximum and minimum values of a waveform.
You might find better help by posting to the LabVIEW Interface for Arduino forum. They will be more familiar with the Arduino functionality and might have ideas how to achieve your desired functionality.
10-11-2014 10:28 PM
helo Steven
thank you very much for your information
10-13-2014 01:32 AM - edited 10-13-2014 01:40 AM
It doesn't look like he is having any issues with LIFA (LIFA is not being used to process the data, only acquire it, which he has accomplished). His questions, as far as I can tell, are about processing the data (which I would not be the best to answer in the LIFA forums; not many people are able to provide support over there since LIFA is effectively deprecated and I'm the most active one there providing support).
If you are curious, he is just pulling 10 data points from a continuous analog acquisition stream (for each loop iteration). The only thing that he needs to do regarding LIFA is to stop the continuous acquisition after the loop before closing the Ardunio (which I will let him know in the LIFA forums as well).
10-13-2014 12:56 PM
Rai,
There is the Array Max & Min function as well. After looking more carefully at your block diagram, I think that might be more useful to you.
08-08-2017 02:18 AM - edited 08-08-2017 02:20 AM
Pls tell me how to connect spo2 sensor to arduino
Anyway thanks, i stll wait for reply.
08-08-2017 02:55 PM - edited 08-08-2017 02:55 PM
Hello Saravanana608021,
Two observations:
1. Your question does not seem to relate to LabVIEW, so it may be best to find support from the manufacturer of your sensor.
2. If your question does relate to LabVIEW in some way, it would be best to create a new post rather than posting on a three year old thread. This will give you more visibility and is better practice.
Good luck on your project!
jordans
