We are making an vision application, where up on obtaining UART commands from other sub unit we need to enter in to specific image processing functions(6 functions).
So kindly let us know which labview design pattern can we use out of Master/slave, producer/consumer(Data), producer/consumer(Events), Qued message handler, standard state machine and User interface event handler design patterns.
You can use the Master Slave architecture,where your master will be getting UART commands and buffer those commands and the slave will read the buffer and do the image processing functions accordingly.
Master/Slave doesn't buffer. You only get the latest command since it uses Notifiers. If you need to process all commands, then you need the Producer/Consumer, since it uses queues.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
