I am trying to decode 288 bits with a rate 2/3 and for that I first depuncture it using your depuncture VI and then rate half decode it. I am attaching the VI and the text file to read from, used in the VI. Problem is I am getting an error saying "Possible reason(s):
Input bit stream contains invalid values (only zeros and ones allowed)."
wrt the depuncture VI. But I have only 0s and 1s in the file separated by tab and each 288 bit set separated by newline. The read spreadsheet VI is giving no error and converting the file to array. Could you please help me resolve this?
Your Read from Spreadsheet File is reading them in as Doubles with the default format of %.3f which means you are getting 0.000 and 1.000. It is throwing up on the decimal point, and the extra zeroes probably don't help either.
