I m using the peak detector vi to detect peaks every 100 samples, if the difference between two consecutive peaks is greater than 15 i want to delete the peak with the higher amplitude only. This data set, should be plotted again on another waveform. I m able to detect peaks that have amplitudes greater than 15, but I dont kn ow how to delete only these peaks.
Attached is the waveform, with a single peak with high amplitude which I want to delete.
Any help would be appreciated.
Thank you.
Regards.
