Hi heelklick,
The code you have submitted must be part of a larger VI since it has obvious parts missing such as the array indicator you are referring to. I have added some indicators to your code and have implemented the solution that I think you are looking for; a Local Variable that resets the array indicator before the loop runs:
A Local Variable is recommended when you have to write data to an indicator outside of the dataflow or when you want to programmatically write to a control.
Let me know if you still have questions!
Message Edited by Philip Courtois on 01-09-2007 12:59 PM
- Philip Courtois, Thinkbot Solutions
