delete from array function and strings containing a minus sign
I amd reading  data from a csv file (string format) and want to delete the first column and put the second column in its place.  This group of strings is a list of filenames I want to pass to another process.  The problem is that some of these strings will contain a minus sign and this "delete from array" function chops the string data after the minus sign. Does anyone have a workaround for this????
Attached is the input and output data, and this piece of the VI
Thank you in advance for you help.
(2,382 Views)
Delete from array does not chop anything.  Your display is only showing part of the string.  Make the string longer, or wider to see the full string.
EDIT:  And you didn't post any source code you posted a picture.  Check out this link under the Posting a Question section.
http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/Unofficial-Forum-Rules-and-Guidelines/td-p/...
(2,375 Views)
Thank you - mud placed appropriately in face.
(2,366 Views)
