02-26-2015 01:54 PM
I have gone round and round witht the examples of using fgen to output a waveform and have not succeeded in getting the output I need.
I have a PXI-5412.
I need the waveform to start at 0V then ramp to some voltage, remain at that voltage for some period of time then go back to 0V. This needs to happen as a single pulse from a software trigger.
(Ultimately, I need to be able to control the slew rate of the ramped portion)
I have tried all kinds of combinations of gains and offsets to no avail.
What am I missing?
Mac
02-26-2015 02:21 PM
02-26-2015 02:30 PM
Sorry, but I can't get any combination of gain or offset to get the ramp to go from 0V to say 1.5V, stay at 1.5V for XmS, then go back to 0V.
It either complains the gain is too high or the offset is too high.
The array is the simple part, right? Say, 256 points from -1 to 1.
I just can't seem to find the aha! moment for this. 😞
02-26-2015 02:35 PM
02-26-2015 02:38 PM
02-27-2015 06:09 AM
Thanks for the replies.
I guess I'm asking things in the wrong way. I understand how to use the ramp pattern to generate arrays of ramp data. And, I understand that I can add more to the array to get the dwell time and then turn it off. But when would one use Util Create Bin16 Waveform Data VI instead? and why?
For that matter, if gain and offset aren't the right thing to use, why? And, when and why are they the right thing to use?
So, I think I generally get the mechanics of how, I'm trying to understand the why so that I can make reasoned code design decisions rather than just use things by rote.
02-27-2015 07:37 AM
