If a breakpoint is encountered, the vi is paused. When the vi is runned
again, sometimes it is still in pause mode from the last run (I fall for
this every time, e.g. when you stop the vi when a breakpoint is encounterd).
You can check this with the pause button, that is red when it's on. You'll
have to switch it off before running the vi (or after you stop the vi).
Wiebe.
"AndyBE" wrote in message
news:506500000008000000D3F90000-1079395200000@exchange.ni.com...
> Hi.
> Once I stepped into a program and/or I set a breakpoint there, labview
> always stops at the beginning of the VI (SubVI) and waits for pressing
> the "run without pausing" Button. But If I have no breakpoint there I
> don't want LV to stop at entering the VI
(SubVI). How can I change
> that? I don't want to change the VI Properties (Allow
> Debugging)everytime. Is that possible at all?
> ANDY
