date and hour from excel
Hi everyone ,
I am a trainee and I am a new user of Labview . I need some help from you to reach my goal.
I need to command a numeric value( voltage value) in function of time range defined on Excel , I sucess to read my excel data and the content of cells but the problem is that I can't make use of date and hour ( string format) and transform them into timestamping on Labview in order to commande the value i wish to drive in funtion of date and hour.
I want that my test start at the beginning time and the duration of the loop is the difference between end time and beginning time.
Please find attached my excel file and my VI.
Thank you for your comprehension.
(2,516 Views)
Hi HajjejAd,
Check the attached VI and feedback us.
(2,498 Views)
Hi Vij@y ;
Thank you for your answer.
I found the solution before you send me your answer which supports my choice i did.
Check the attached VI and feed back me.
(2,473 Views)
