data dashboard with sbRIO 9631
i have made one vi of fpga led which turns on and off led of sbRIO and then it is used in real time . i want to create a shared variable so that i can see my led on and off in data dashboard and in parallel it should be on and off on sbrio too. i am attaching two vi of fpga and one of rt please help me how to create shared variable in it if i can get help with any vi
(2,533 Views)
Accepted by topic author AjinkyaM
Hi Ajinkya,
In order to interact with data dashboard you need to publish the data from the real-time portion of your system to the network. To do this you need to use network published shared variables (NPSV).
http://www.ni.com/white-paper/4679/en/#toc3
I would also read through chapter 4 from the cRIO developers guide which will help explain a lot of different networking options.
http://www.ni.com/pdf/products/us/fullcriodevguide.pdf
It is important to note that only NPSV are able to connect with data dashboard which is explained below.
http://www.ni.com/white-paper/13757/en/
Finally, to use NPSV on an sbRIO/cRIO you need to make sure the variable engine is installed on the sbRIO which I believe is covered in the cRIO developer guide but I have also provided a link that covers adding/removing software from an sbRIO/cRIO.
http://www.ni.com/gettingstarted/setuphardware/compactrio/controllersoftware.htm
Patrick H | National Instruments | Software Engineer
(2,317 Views)
hi,
 i have created it and its working succesfully now. thank you
(2,300 Views)
