data communication between Micro-controller and labview using Ethernet
Dear engineers,
I am trying to make a data communication between AVR micro-controllers and labview via LAN port.  I am able to read the data in Internet explorer but I want to read the data in labview.
Any experience for this case ?
Thank u in advance,
Ped
(2,496 Views)
Look into the TCP/IP examples in the LabVIEW Example Finder (Help->Find Examples).
You could also use VISA.
GCentral
(2,495 Views)
thank you for your help. could you please provide me an example? I couldn't use TIP/IP modules. I could transfer data using HTML code and I check the results internet explorer. but unfortunately I was unable to send and receive data to labview.
(2,431 Views)
If you're already having success using HTML commands, try reading through this: http://zone.ni.com/reference/en-XX/help/371361G-01/lvconcepts/interacting_vis_ws/
(2,417 Views)
Don't think its the best way to do things but you can open a browser window in Labview and capture all communications and pars it for a given value. etc.
Also note that on Windows and i.e underlying communication is different than say Fire Fox or Chrome.
post your VI for specific details.
Barddya
(2,403 Views)
When you say that you can transfer the data using HTML code, do you mean that in a browser you can type in a URL and get the data back? If so, you can do the exact same thing using the HTML client VIs.
Posing as a browser, the LV code accesses a website url and returns whatever the server sends as a string.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,386 Views)
