10-01-2014 06:40 AM - edited 10-01-2014 06:41 AM
Try this. I added the DAQmx Wait Until Done VI with a timeout of 10 seconds.
10-06-2014 11:37 PM
hey crossrulz..
thanks for reply... i tried your vi bt i do not work and gives error.. i am giving 10 KHz square wave as input clock and port are connected to fix supply to show binary "10101010".
i attached error message here. plz help me out here..
10-07-2014 06:04 AM
hello..
i also tried my code without external clock and i am getting output. so plz tell me wht might be wrong here...
regards,
Dharak
10-07-2014 06:25 AM
Have you connected your clock signal to the right pin ?
What card and what pin on that card are you using?
10-07-2014 06:29 AM
i am using pci-6534. and i am giving clock via signal generator and i connected it to PIn PFI 2 and also tried PFI 6.
10-07-2014 09:41 AM - edited 10-07-2014 09:47 AM
As far as I can read from the documentation, the PFI6 (Port5/line2) is output, so that would not work.
Can you then verify that you have connected the signal generator to port4/line2 (PFI2) ?
You can use that as an input port also, so make a small test vi that reads port4/line2 and see if it changes in a known pattern and rate. Set the signal generator to a low frequence so that you can monitor it.
How many samples have you requested and what have you set the timeout to?
10-08-2014 12:56 AM
hey all...
now my application is working.... thanks to every one for helping me out
10-08-2014 04:03 AM
hey all,
i had some issues with my function generator so problem was occuring to generate clock.
--> now i have to check at what maximum rate i can acquire data and update graph.So plz tell me how to proceed for this task. and plz share document regarding it.
regards and thanks,
