daqmx node relativeTo Most Recent Sample slow loop
I'm reading AI using DAQmx M series device using Continuous Mode. I got an delay in reading loop.
My setting:
NI-USB 6255
AI: 64 CH
Sampling rate: 15kS
Sample per channel: 15
The reading loop should be = 15/15k *1000 = 1ms
However, when using DAQmx node:Most recent sample -> RelativeTo
I got 1 reading loop =10ms.
Even I changed the Sample per channel to 20 or 30, the loop still 10ms.
Could anyone know this issue?
(2,658 Views)
Hi kebimat_f,
Do you think you could post a snippet of your code so we can get a better idea of how you're configuring your AI?
Here are some resources for reading an analog input with DAQmx:
https://www.ni.com/en/shop/data-acquisition-and-control/what-are-multifunction-io-devices/taking-a-m...
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
Also, make sure you have your DAQmx Open and Close VIs outside of your reading loop.
Sunayna R.
Applications Engineering
(2,616 Views)
Dear Sunaenae,
I attached the VI here. Please check
Thank you!
(2,576 Views)
What exactly are you trying to achieve with the Relative To property -- what is your end goal in terms of how you want to acquire samples?
It looks like everything is configured correctly from your code.
Sunayna R.
(2,542 Views)
