01-25-2014 05:46 PM
I am running a scaled down earthquake data that I retrieved from the USGS website and placed accelerometers on the mini shake table to verify that the shake table can replicate an earthquake. However, I have a problem setting the "samples to read" and "rate (Hz)" to the correct setting to give me a good amount of points. I extracted the data into excel file and plotted the graph but because I have so many collected data points, I cannot the plot. Is there any way where I set the settings of the DAQ assistance to only give me a few points? Ultimately, I want to get my excel graph to have the same shape or very similar shape as the earthquake data that I retrieved. I attached my block diagram, DAQ assistance setting, and the graph of the earthquake data I am trying to replicate. Thank you in advance for your help!
01-27-2014 04:21 PM
What problems are you having? Have you tried playing around with/lowering your sample rate? You can also try decimating your signal using the Decimate 1D Array VI, though might not be the best way to do this.
01-27-2014 05:21 PM
01-28-2014 07:43 PM - last edited on 01-03-2024 01:34 PM by migration-bot
This VI would appear to help a lot with your problem. You would have to play around with the dt. https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/measure/maresamp-llb/resample-wavef...
