03-31-2015 12:24 PM
03-31-2015 07:50 PM
04-01-2015 03:47 AM
04-01-2015 06:00 AM
04-01-2015 09:30 AM
How do I calculate the number of cycles generated?
04-01-2015 10:18 AM
If you want to generate waves continually, you can add while or for loop.
And use parameter "i" inside the loop, and you can know what cycles in your program.
Patrick
04-03-2015 12:19 PM
Hi Patrick
I think with the parameter "i" know I can program cycles but not the cycles of the waveform.
Thanks.
04-08-2015 05:03 AM
Because the counter restarts all the time?
04-08-2015 06:54 AM
Use another Shift Register on the outer loop to hold the count as well. Right now, the count will be reset each time you run this check (shift register is being initialized to 0 each time the FOR loop is started).
04-08-2015 08:58 AM
Hello.
Can I have it I can explain graphically? I have little experience in labview.
Sorry.
