custom error codes
A few years back I created a list of custom error codes for my project..and forgotten what I did.
Since then I want to add an additional code.  I found the file.."xxx-errors.txt" that I used.
1) How does Labview 2012 know to use that file??  I don't see a path to it anywhere in the vi.
2) can I just go in and edit the txt file by adding my new error code if I follow the pattern in the current txt file??
(3,358 Views)
Accepted by topic author Clint1000
You should store custom error files into a special folder:
<LabVIEW>\user.lib\errors
When launching LV, it will load these files.
If you change or add files, you have to restart LV for these changes/additions to show up.
For modification of error files, you should use the Edit Error Codes tool in Tools >> Advanced.
Norbert
Expert: Geometry
(3,349 Views)
Thanks..
(3,335 Views)
