02-24-2009 03:58 AM
Hi All,
I have recently created myself a custom probe by right clicking on a string, creating a new probe giving it a name and saving it under the Labview/probes directory. However when i right click a string and select probe (I am wanting the default small box probe) i instead get my custom one automatically. I want access to the default one all the time but instead keep getting my custom one! Surely if i want my custom one i shall select probe->custom probes->mycustomProbe. Does anyone know how to undo this?
Thanks in advance
Craig
02-24-2009 04:09 AM
Hi Craig,
i allways get the last used custom probe. You should select custom probe and then the standard probe. The next time you select probe you should get the last used one (in this case -> std).
Hope it helps.
Mike
02-24-2009 04:22 AM
Ahhh Wonderfull,
As you said, select generic probe, then you get the last probe used as default 🙂
Thanks Mike
