02-05-2013 05:44 AM - edited 02-05-2013 05:51 AM
Hi everybody, i am having a problem at curve fitting function,
i take at output, what i give as input, where do i make mistake?
at example i give 4 values, if i enter 6 values it works, but i need to do it with 4 values.
any ideas?
thanks
Solved! Go to Solution.
02-05-2013 05:53 AM
take a look a the help topic about the non-linear fitting VI :
Apparently what you did was creating a constant on the f(x,a) termanial, this then causes an error because the VI is expecting you to create a VI from a template. You either have to create that VI or use a different fitting method.
Hope this helps
Epictetus
02-05-2013 07:26 AM
Hi, thanks for ur answer
I did it with nonlinear curve fitting function, but there should be some mistakes, still doesnt working?
02-05-2013 08:37 AM
Bye the way, i dont know how to decide initial parameters, can anybody help me with that?
thanks
02-05-2013 08:42 AM
What's wrong? it works fine for me... what error are you getting?
Of course you need to input an array containing 3 values in "initial parameters" for the initial values of a1, a2 and a3.
Hope this helps
Epictetus
02-06-2013 05:00 AM
thanks, i didnt put 3 values for it, i will try it like that.
and how can i determine, which values should i write as initial values?
02-06-2013 08:20 AM
i entered 3 value as u said, now i dont get any error, but output is same as input. function doesnt make any curve.
if u got curve, can u share ur initial parameters with me
02-06-2013 10:55 AM
Please include your data. What values are you using for Array and Initial Parameters? With only 4 data points you may have a system which either matches perfectly to a the curve or which cannot be matched by a second order curve.
For example an input of 0,3,3,0 with initial = 2,2,2 produces -6.8E-17, 3, 3, 1.7E-15 which plots identically to the input.
Lynn
02-06-2013 12:58 PM
Your function is a simple quadratic polynomial, so you should use the general polynomial fit function instead. Don't overcomplicate things 😄
02-06-2013 01:03 PM
sorry, i thought datas will be visible if i upload program.
i used as input
0.005
-0.05
-0.05
-0.005
as initial values, i have no idea what should i write, which value:/.
i need to do it with 4 data,
thank you
