06-03-2014 08:53 AM
Have anyone solved the error 314004 from the TCP using the example template vibration data logger ?
Cheers
06-18-2014 05:27 AM
Hi Leapingfrog,
I hope you are well.
Are you still having this issue?
I have a number of suggestions/questions for you;
1) Ensuring that the Network Streams software has been installed correctly on the device. (Via MAX)
2) Format the CRIO by opening MAX, right click - format disk, then reinstalling all the relevant software.
3) Are you able to connect with no issues to the cRIO through the project explorer?
3) Could I ask at what point this error is occurring in the VI?
I look forward to hearing from you,
Kind Regards,
06-18-2014 07:55 AM
