11-28-2015 06:03 AM
Hi
I need to connect a usb device and read in serial mode. The device is recognized in MAX as
USB0::0x403::0x6001::A703D8LA::RAW
When I set the visa resource as the above line and try to read it, it gives Error code 1073807331. The interesting thing is that I have successfully connected to the USB device from the usb port of sbrio 9607 before with the same program. In sbrio the device is seen as ASRL8:INSTR which is a major difference from the crio 9082.
Dees anybody have an idea about this difference between two NI platforms?
Thanks in advance
Engin
11-28-2015 06:11 PM
The 9607 runs Linux RT and the 9082 rus Pharlap ETS:
http://digital.ni.com/public.nsf/allkb/35F1FD98520D6E0E8625783A005AF557
You'll probably have to stick with LinuxRT cRIOs for the device to work ask you expect
