creating flexible object in 3d picture control toolkit
How to create a flexible 3d object using 3d picture control tool kit. I can rotate, translate and scale a object but i cannot make to bend it... Help me ?
Message 1 of 9
(3,936 Views)
There is no such thing as a flexible object. If you want the object shaped differently, draw it differently.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(3,911 Views)
hi gokul2013,
with "bending" you mean to interacte with a 3d object e.g. a surface? This reminds me of an submission from the 2010's code contest:
https://decibel.ni.com/content/docs/DOC-13861
Alex
Message 3 of 9
(3,894 Views)
Thank you for your kind reply Mr.Alex.
You reply was very helpfull to me.. I can do bending movement with what you had proposed in early reply.. For my application i need to make my object as flexible. Here i have attached my object file. Just i created a two box Objects. In that , I need to bend green coloured object as like in attached Picture file..
For this purpose what i need to do and how can i code the program..
Looking for your reply...
Regards
Gokul
Message 4 of 9
(3,869 Views)
Sorry, I don't know, because I haven't written the .vi which I linked in my earlier post.
My intention was to show, that Labview is capable of this task.
Alex
Message 5 of 9
(3,858 Views)
You can't do it with the 3D picture control unless you make your bending object out of a bunch of discrete shapes that you calculate the new positions of with each change in angle.  You'd essentially be building a low res rendering engine.  If you are looking for a way to do this, and are not tied to LabVIEW, you may want to look at something like Blender3D, an open source animation and game engine software package, where you can dynamically adjust shapes like this.
You could make an animation in Blender to account for a bunch of discrete bend positions and export them as seperate STL files.   Then you could load the STL files into memory (or one at a time), and display the correct one based on the rotation value in a LabVIEW control.
Message 6 of 9
(3,851 Views)
Did you try vugie's example? It seems quite possible to redraw the green object with a different shape based on the mouse drag.
Message 7 of 9
(3,842 Views)
Any one tell me how to create 3d robotic arm using labview?
Message 8 of 9
(3,435 Views)
You appended onto the end of a thread that is more than a year old. You need to post a new question -- and when you do you need to add some more detail.
For instance, I assume you are wanting to create the picture of a 3D robot arm. You need to say exactly what is is that you need and what it is that you are trying to do.
Mike...
LabVIEW Champion
Message 9 of 9
(3,428 Views)
