create waveform with buffer data
how can i create a waveform with buffer data from my counter.
( with Fe = min 1khz )
The reference VI is comming from Labview exemple
sorry for my bad englisch
Comment est-ce que je peux créer une waveform a partir de données issues du buffer d'un compteur.
En gardant une grande fréquence d'echnatillionage min de ( 1khz )
Le VI en réference est un exemple issu de Labview
Merci
(2,401 Views)
From your example it looks like you are recording the count value at 100kHz.
To build a waveform with "Build Waveform.vi" you need at least 3 items:
1) t0 = start time of waveform
2) dt = time between waveform samples (dt = 1/100,000)
3) Y = array of data
(2,398 Views)
thank's for your anwser and sorry for my very bad english.
The input of my counter is a PFI ligne
the outpout  array of data buffered is a 1D
I want to create a waveform, with the values of the buffered data.
When there si no event of the input counter, the waveform should continue with the last data
Y ( array of data )  have two value, the number of count and the counter value, i jsut need de counter value
The input of my counter is a PFI ligne , wath value should i take for dt.
To : is the start time of waveform, ok, but sould i put a counter on this input, or just a constant
thank's for youre anwsers
and sorry for my bad english
David
(2,385 Views)
